meter tails who owns what
The meter tails from meter to consumer unit are the property of the homeowner, but what if the supplier have fitted an isolation switch, does the homeowner own from switch to CU and supplier from switch back?
To clarify, the tails from the meter to cu arethe customers. If you need them replacing you need to get your supplier out to install and isolater. Then the tails to the ingoing of the isolater are the suppliers responsibility. Absolute madness if you ask me but it is what it is.
To clarify, the tails from the meter to cu are the customers. If you need them replacing you need to get your supplier out to install and isolator. Then the tails to the ingoing of the isolator are the suppliers responsibility. Absolute madness if you ask me but it is what it is.
Correct ta-mondo.
