Guest viewing limit reached
I work for a company who installs electric heaters.
Usually we remove old storage heaters and replace them with our heaters using the same point with a new switched fcu.
The fuse board is usually just an old Wylex type with just an on off switch and non switched fuses.
The board is powered from the live coming out of the radio teleswitch meter so to make the board live 24 hours we remove this cable and put it into a Henley block which has permanent live feed.
The questions are....
Are we allowed to touch these meters as there are stickers all over them saying property of the electricity board.
Secondly, using the old points coming from the old style board with just an on off switch. Is this ok?
Some electricity supply companies don’t use separate meters for economy 7.
They just charge a different rate for all electricity used during the off peak times.
However, it sounds like these new heaters are not storage, and are designed to be used at any time.
Yeh you are messing with DNO equipment and you can be prosecuted in theory at least. Although I think we all know it is very rare if ever. And @ipf I guess they will be fed from Henley blocks, I did mean when they bypass the E7 and go on to what is an E7 tariff daytime rate they are gonna faint when they get the bill.
Yes all the electricity in the house is cheaper over night because of the tariff.
Forget the tariff and the prices of electric etc.
I’m more curious as to should we interfere with these meters belonging to the electricity board and is the fuse board ok considering it is old with only an on off switch.
If your altering it, you should know what BS7671 requires. Perhaps you should say what you have done exactly?
Sounds like new supplies to circuits so it must be altered.
Existing circuits re fed from a different, existing, CU.
Minor works.....one for each circuit, I wonder.:(
This will be something similar to Fischer heaters?
I'm surprised an employee of a company that's in the business of exchanging Storage heaters for high efficiency heaters is on a forum asking basic information like this.
Is the company NICEIC or similar registered, do you have a Q.S or other electrical installation Professional?
Who supervises the installations work?
Who decided on the method of installation?
and many more questions.
Leicester
Meters and boards Question
Luke105,
