Metrel easi tester | Page 2 | on ElectriciansForums
Discuss Metrel easi tester in the Electrical Tools and Products area at ElectriciansForums.net
The leads are a year old. I'm charging the battery at the moment but it was showing about 1/2 charge I guess when I was testing earlier. If its as simple as a low charge then I'll be delighted.
I had the same problem with mine. Found a loose connection inside connector/probe end of one of the test leads. Re-soldered connection, good as new. No problems since.
Reply to Metrel easi tester in the Electrical Tools and Products area at ElectriciansForums.net
Hi everyone, If you are looking for reliable EV chargers, check out our top-rated selection at E2GO! âš¡ Please note that all EV Chargers and...
Why do you need a ‘compatible’ adapter? The cheapest Ethos EV adapter from CEF can put the charger into all modes and allows Zs and RCD testing. I...
KT66EVA (KT66DL & KEWEVA) - £1073.60 + VAT if you shop about as a combo
