Metrel easi tester | on ElectriciansForums
Discuss Metrel easi tester in the Electrical Tools and Products area at ElectriciansForums.net
P
philip962
Has anyone got a user/instruction manual for the mi3000 easi tester as a **** I have lost mine cheers everyone
think i may have one mate i will have a search on the hard drive. if not i am sure but i think if you go to metrel and pop in the serial the site will let you download
I have a mi3000 can't see manual on metrel downloads site,never been happy with the tester seem to get very different readings on insulation testing anyone else had same problems?
For me it was a bit of figuring out to at first but now I find it simple to use. I personally really like it in all honesty, never really had any problems with it and have had it for the best part of a year.
I realise that this is quite an old post .... but yes, I have been getting some very odd Insulation Resistance readings. Did you find a solution?
The leads are a year old. I'm charging the battery at the moment but it was showing about 1/2 charge I guess when I was testing earlier. If its as simple as a low charge then I'll be delighted.
I had the same problem with mine. Found a loose connection inside connector/probe end of one of the test leads. Re-soldered connection, good as new. No problems since.
Reply to Metrel easi tester in the Electrical Tools and Products area at ElectriciansForums.net
Hi I thought it was with amendment 2? Haven’t double checked.
Why do you need a ‘compatible’ adapter? The cheapest Ethos EV adapter from CEF can put the charger into all modes and allows Zs and RCD testing. I...
KT66EVA (KT66DL & KEWEVA) - £1073.60 + VAT if you shop about as a combo
"When stoned..." Brilliant!
Hi, Ive got a couple of Megger PAT 450 testers, and, for a number of reasons, Im not happy with the printer it comes with. Does anyone on here...
Trending Electricians Tools
New job, new tester; Megger 1741+, those that have one; anything good/bad to report? Work also trusting me with a Flir E5 magical heat-reading...
96K
Absolutely correct they hold water, shrouds are totally unnecessary. 20s is 24mm spanner, 20 large is 30mm spanner.
45K
If that little thing, plugs your butt, you better eat slowly. 🤣
2 3 4 5 6 7 8 9 10 11 12 13 14
41K
B
I'd say everyone has knowledge gaps in their area of electrical work I know i have quite a few i work on to fill them in
2 3 4
29K
I too have been tempted.. I’m buying for my son. He’s in his2nd year at collage and looking for apprentiship. Sadly it’s almost impossible in my...
25K
Of course. “Ye canna change the laws of physics” EDIT. oh blimey, I just spotted the date of the OP. ? Thank you very much @Lord lee jan You...
23K
Only way to do it in a tight space
22K
The display on the Mft pro is not very durable mine is broken already 😡
21K
Only lawyers , solicitors and dodgy chat up lines charge for picking up the telephone 🙃
2 3 4
20K
J
I'm not entirely certain as it's very tough, but brittle when cold.
2 3
20K
nicebutdim
N
