Does anyone know if its ok to replace a small double radiator plumbed in 8mm microbore with a new 500x1500 towel rail with 15mm fittings. I do not know whether the central heating system has manifolds or not, probably it does somewhere, I haven't seen them. A new combi boiler is in place. I had a plan to get a friend in to solder 2 15>8mm reducer on then bring the tails up in 15mm copper from under the floor.
any advice welcome
any advice welcome
