M
mevans12
Hi
I'm not an electrician but am merely seeking some advice.
My property circa 1930's is wired with Mineral Insulated Cable. We are in the process of emigrating and wish to rent out our house, and understand that it’s wise to get a Periodic Electrical safety test done. The fuse box we have is old style with cartridge fuses, and has no trip (think RCD is the term?) switches.
Is it possible to install a new type consumer unit with RCD's without having to go to the expense of having a full re-wire?
Any advice re dealing with MIC and obtaining a safety certificate would be appreciated.
A friend also not an electrician has suggested installing a new consumer unit, then using the old fuse box as a junction box to connect the new consumer unit to the MIC. He did say that there was a risk that if any RCD picked up a fault it would be difficult to find. Any comments re this suggestion, or am I looking at a straight re-wire?
Many thanks.
Many thanks.
