P
panicoll
haha i didnt even know it was in edinburgh will need to give the guy my number.
Shocking I am only 22 and have worked with more Ex d pyro installs than you old timers!
You Best thing to do is have a PIR done and as a landlord you should only worry about Code 1 or 2's.
oh and Pyro doesn't need to have additional protection(RCD)
You wouldn't have to be a genius to know how to stick a new metalclad board in there. If you had even just a small amount of experience with pyro you could quite easily terminate the existing glands into a new board. The only problems would come if that was not possible and some stripping and re-potting needed to be done which is doubtful.
Again though, as UNG has already mentioned, how you would be able to tell a chancing Electrical Trainee domestic spark from a domestic spark with some experience of pyro is gonna be a hard thing! Maybe ask them what method they use to strip MICC? Or maybe you could ask them what hygroscopic means? Easy answers to find on google but not so easy to answer when put on the spot! Who knows.
I doubt that little statement!! lol!! Those older sparks that have worked on MICC, would have worked on far more installs than you have. Ex d or normal, there isn,t a great deal of difference, apart from the gland itself....
As for using wheel straightners on this small size of MICC's .....those cables would have had to of been in a really bad state, for the wheels to work harden the sheath. To be honest i can't remember anyone using those wheel straightners on such small dia cables, they were generally used on the larger cables....
I think the general advise would not to let any house bashers even consider the job lol let them stick to crawling about lofts with the glass wool! hehe
