Minor Works Cert help | Page 3 | on ElectriciansForums
Discuss Minor Works Cert help in the UK Electrical Forum area at ElectriciansForums.net
Berkshire
So I am currently registered with the NICEIC as a domestic installer, but I need to fill in a minor works for adding a spur to an existing ring as a dental surgery.
As I can't do this via NICEIC, can I download a model form, fill that in and give it to the client?
I've seen a couple of model forms online which all have a 'registration number' box at the bottom of it, which I'm not sure what they're after?
Thank you
Providing your certificate contains the same information as is contained in the model forms in BS 7671, then you can create your own. I have an Excel spreadsheet I fill in and print for minor works.
You might also want to check with your insurer that your covered for work in commercial properties.
I can see everything wrong with him fraudulently using the NICEIC logo and forms which is what using them outside of scope would be doing. Presumably non-domestic forms aren't even made available to DIS registrants.
If I not wrong here I think the OP is a D.I. and can use the purple certificates but they have the word "Domestic" on them and the OP does not want to send one with that to a commercial customer.
He's not entitled to use it outside of scope.
Reply to Minor Works Cert help in the UK Electrical Forum area at ElectriciansForums.net
Thank you all, yes I didn’t think they do and I have done minor works but the helpline was not very helpful. Got my yearly assessment soon so I...
