Minor works? | Page 2 | on ElectriciansForums
Discuss Minor works? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
you can use 16A MCB for sockets. depending on the load. if it's only for power tools then 16A MCB on a 2.5mm radial will suffice.
you can use 16A MCB for sockets. depending on the load. if it's only for power tools then 16A MCB on a 2.5mm radial will suffice. and then again, it all depends on the current capacity of the cable feeding the garage, and it's own O/C protection.
Will have a closer inspection of the cables running into the garage when I go back. Thinking about it at the CCU it did look like 2.5mm now i think back.
It's not in the "regs" its part of Part P - see additional notes for Table 1 and 2.
thats where i normally refer to and it states garden lighting is a special installation and therefore notifiable??​
Under additional notes (page 8) notes e, and f indicate atteched and detached garages are not considered special locations.
Then on the next page under General guidance note i, it states:"The installation of equipment attached to the outside wall of a house (for example security lighting, air conditioning equipment and radon fans) is not notifiable provided there are no exposed outdoor connections and the work does not involve the installationof a new circuit or the extension of a circuit in a kitchen or special location or associated with a special location."
cheers spin
Reply to Minor works? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
For a new circuit or alteration the dead tests should be done first to ensure it is safe to energise.
You can obviously put N/A in some of the boxes like the cable size etc because you haven't used any, you can do a loop test at the thermostat and...
