MK consumer unit SPD's | Page 3 | on ElectriciansForums
Discuss MK consumer unit SPD's in the UK Electrical Forum area at ElectriciansForums.net
pembrokeshire
Hi all,
I'll be wiring up two small new builds, the customer is supplying all the materials, they supplied MK consumer units, the problem is it doesn't seem MK are doing SPD's for their boards.
Any one know of a SPD that fits MK boards?
Thank you in advance
A Fusebox SPD kit is just £30 these days and if a customer can't be convinced to spend the £30 to protect a four figure sum's worth of equipment then I'm not sure I want them as a customer.
At least with amendment 2 it's as simple as "ok, sign here that SPD was advised and you are declining one".
And whether they do any good or not they do make the consumer unit look more exciting!
Reply to MK consumer unit SPD's in the UK Electrical Forum area at ElectriciansForums.net
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
It looked like the live connection side ( internally) burned against the neutral of the main switch
