mk rcd tripping | Page 2 | on ElectriciansForums
Discuss mk rcd tripping in the UK Electrical Forum area at ElectriciansForums.net
Darren-Sparky
hi, today i installed a 8 way mk rcd i had from left to right;
100a main switch
63a rcd
40a mcb cooker
32a mcb ring main
16a mcb immersion
6a lighting up
6a lighting down
tns system, i did my tests before i installed new consumer unit and all was good, when i tried to turn on cu the rcd would trip immediately, but other times i could turn on the cu and rcd would stay on but as soon as i plugged anything in to a socket or switched a light on the rcd tripped? also the test button would not operate i replaced the rcd with 3 new ones just incase and all the same results an intermittent fault that never really occurred more than once.
ive checked polarity of incoming tails and all seems good, i also couldnt get rcds to trip using my rcd tester,
any help would be appreciated
thanks
Whether he's a winder upper or no,he has this thing about changing Rcds
Here now and in the other thread
Being a sucker for winder uppers, I am going to wait and see if there are more clues coming from his posts before engaging in drivel
Reply to mk rcd tripping in the UK Electrical Forum area at ElectriciansForums.net
Have you notified Building Control of these works?
Thank you for taking the time to help explain this - much appreciated
