MK sentry busbar configuration
Not a bad board at all, If I came to one like that I would be happy.
You can see where things go, it is neat, OK the cables aren't dead straight but they are clear cut, you can get to everything, certainly not a rats nest, you have hidden all the extensions and there do not look to be any errors; just make sure all your connections are tight when you go back to it as they can settle a bit and you are all sorted and safe.
Good to hear you are getting some good work going forward I hope it leads on to more.
