MK switches 10amp | on ElectriciansForums
Discuss MK switches 10amp in the UK Electrical Forum area at ElectriciansForums.net
A
allybally
I'm just wondering, Is this 10 amps per switch or overall, or per switch, I've got a 2 gang switch thanks
so you have 3 kw on a 10 amp switch then? oh dear :bulb2: what size cable and circuit breaker is on the circuit? what type breaker? and how did you calculate your load?
I haven't calculated anything yet! And I know what ratings to put per cable and what breaker to put it on, shall I just ring MK? If I have a 8 gang plate with 8x10 amp switches in does that allow only 1.25 amps per circuit!
why do you need to ring mk? the switch is 10 amp rated, if you know the load then thats all you need, 3 kw is 3000 watts which is approx 4.3 amps per 1000 watts at 230 volts, thats approx 13 amps ish, so the question is how have you calculated the load? and is the cable up to the job? and is the right breaker there after you tested the ZS?
okay another question for you, if you put both switches down will the 10 amp rating of the switch be safe for the load connected to it?
Reply to MK switches 10amp in the UK Electrical Forum area at ElectriciansForums.net
Being pedantic, the Crabtree 50A cooker switch is a 4500/1, which has 'cooker' printed on it. For a shower, you require the 4500, which is the...
We just left it as it was, again the customer didn't seem too bothered, dont think she wanted me digging any further.
