I think I'm having a blonde moment, what's rt3? A root of 3?
I still can't get the answer on my calc
Square.r3(VxIxPf) but I don't have I
Sorry mate I realised I was wrong and edited the post. could you delete that please lol.
I used brackets for the calculation because if I type it in the calculator without them it wont work.
with the 230 V question you dont need the brackets
My only issue with that it's with brackets and without brackets gives 2 different answers
Question 1
So A needs to be increased to 10A
10x0.2=2V
5x0.2=1v
Totally 3V
230-3v=227
Answer D
Yet my tutor said it's C
Can someone else see what answer they get please
Question 2 and I'm struggling with this because I don't know the correct formula
The line current of a 400V three phase load of 8kW at 0.8 power factor is
A. 11.54A
B. 14.43A «------ tutor said it's the correct answer
C. 20A
D. 25A
But it was time to leave and I want to know the formula
Isn't the answer the line current
The 400v surely is the line voltage?
You need carol vorderman sitting next to you in college...... the maths side of it and formulas drove me nutty!!
The voltage across B.
So, 15A through the top and bottom left 0.1Ohm and 5A through the top and bottom right 0.1Ohm
So dropping 2 * (15 * 0.1 + 5 * 0.1) = 4
Right so Volts x Amps x power factor equals Watts.
So 230V x 56.86 Amps x 0.65 Power factor Equals 8500.57Watts
It is the answer mate, to get 24Amps I mistakenly did 8500/230 x 0.65 .(wrong answer)
It is actually 8500/230/0.65 equals 56.86A (correct answer)
Remember what the brackets are doing in the calculation in terms of seperating the numbers.
