mortgage retention advice for current installation upgrade | Page 6 | on ElectriciansForums
Discuss mortgage retention advice for current installation upgrade in the UK Electrical Forum area at ElectriciansForums.net
W
walkthenrun
Hi guys,
i need to carry some work out to get my house to pass its mortgage retention, i had a mate from napit come round and do a electrical installation inspection condition report, as one of the retention on my mortgage is due to the old electrical installation. at the moment there is a 15 way merlin gerin consumer unit. I have identified all the circuit apart from one 15A breaker. anyway i was hoping to change the current unit to rcbo's i think this is probably the best thing at the moment considering the size of the house so if anything does go rong i can localise the problem more easily. guys i have come for advice as i dont know which unit to buy? am i doing the right thing by going for rcbo's. i need something that will allow me have at least 13 different circuits. the only thing i have found upto now is a Wylex 11 way Consumer Unit Type NH1104 that i could put 11 circuits on. The immediate advice my friend give me was to condition report was to update the consumer unit so that the shower is rcd protected, the lights in the bathroom are ip65. the supply to the summer house and the pond shed is in swa cable. is it possible to just take the current consumer unit and swap it directly for an 11 way rcbo consumer unit. would everything carry on working as it is working perfectly now.
i have identified each circuit as follows
1. annexe consumer unit and outdoor floodlight consumer unit (60A) (10mm cable and 2.5mm)
2. cooker (50A) (6mm)
3. upstairs sockets (32A) with two fuse spurs in garage from ring final in above main bedroom (2.5mm)
4. downstairs sockets (32A) (2.5mm)
5. 15A?
6. 5A lights in boiler room (G), garage(G), utility(G),main bathroom(U), small blue room(U), hallway(U), pink room(U) and kids room(U) G-ground U-upstairs (1.5)
7. shower (50A) (6mm 8.5kw shower clipped direct to wall)
8. main bedroom (U) and ensuite lights (U) (5A) (1.5mm)
9. kitchen(G) dining room(G) sitting room (G) and toy room lights (G) (5A) (1.5mm)
10. boiler (5A) (1mm)
11. Pond shed hager consumer unit (60A) (10mm)
12. summer house volex consumer unit (60A) (10mm)
some pictures are included thanks
[ElectriciansForums.net] mortgage retention advice for current installation upgrade
main consumer unit
main c.u and outdoor lighting c.u
pond c.u
summer house c.u
annexe c.u
thanks in advance for your immediate advice if any more pictures are required please let me know thanks
Get a 'Satisfactory' EICR (ie no C1s or C2s) off your two mates, give it to your mortgage provider, get your ÂŁ20K off their grubby little hands, then work on your installation at your leisure!!!
It's your own house and you're a Trainee Electrician, aware of any risks, go for it!
i will be carefull and carry out work under safe isolation and following the best practice possible. i am also going to eventually get all the work done to a good standard inline with current regs but for now the main priority is getting it safe for family and identifying any potential problems
as for inline fans.....................
crack on mate, so long as you get a large air change rate they work wonderful, dont get wickes own inline as thats just about 45l/m whereas you can splash out and get a full on 140/160 l/m fan that will suck the water straight out the shower and out thru the fan before it even touches you lol.
people do tend to get pedantic on this site, but you have had some good advice, when you get your eicr, look thru it do the required work and for now ignore any C3's, get your dosh from el banko.
encourage your mates to show you or help you to understand where the faults are at the moment.
people on here can only speculate as to the best way forward, but your mates can give you proper informed advice
thanks for the information on the fans now i know what i am looking for i can just buy something decent straight away. i have had some excellent advice and appreciate everyones input murdoch without a doubt is right that friends are there to be asked and to get help from, i do really appreciate every persons input and am very great full i will keep this post up to date and let you know of any changes that are made to make the installation safer
would this kind of spec fan be ok
AIRFLOW AV100
Airflow Aventa 4 inch inline extractor fan
Specification
Air Extraction : 187m3/hr
Air Extraction L/s : 60 L/s
Noise : 34dB(A)
Watts : 28W
if not are there any brands you can recommend
Reply to mortgage retention advice for current installation upgrade in the UK Electrical Forum area at ElectriciansForums.net
Given that, it probably makes sense to TT the shed, unless you can be sure it doesn't act as an extraneous-conductive-part. (The SWA won't have...
As the cable itself has had the cpc cut off at both ends I would enter a C3 as it doesn't offer any protection within the cable if accidentally...
