motor starter for conveyor | Page 2 | on ElectriciansForums
Discuss motor starter for conveyor in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
It's the small conveyors that cause the problems, people take them for granted.
I wouldn't contemplate a conveyor without pull switches.
Tony, perhaps in the sort of work places you've worked in, pull cords are the norm.
Imagine the chaos if you had half a dozen workers picking from a conveyor.
Much better to have an indirect drive which will slip under too much load and push button 'E' stops at each work station.
Courses for horses.
the motor using wye connection...from what i learnt wye connection have neutral wire...so i have to use neutral wire too? because without the neutral wire the conveyor still moving..
why conveyor got thermal control??
Was not aware that pull wires are required.
When did that come in?
Machine safety directive. It is also desired to have two channel safety relays for open style conveyors, as access to moving parts. Can't remeber the date whin it came in, could be 2006 or so.
I`ve actually worked on a few conveyors at work, replaced the pull wire + EM stop unit, was faulty. But yes let me take over. Basically you put the wires where you were trained to put them. That is all. :)
Reply to motor starter for conveyor in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I think it was too early yes I meant 3 not 2, but great I'll give that a whirl and thanks.
plugging anything into the 12v socket will still going to drain the battery if the engine isnt running.
