moving an ev charger | Page 2 | on ElectriciansForums
Discuss moving an ev charger in the UK Electrical Forum area at ElectriciansForums.net
my son has recently had an ev charger installed for his car (last week) cost was ÂŁ900, simple run ,consumer unit on outside wall ,drill through to garage and armour cable run of 3 metres to the charging point.Not disputing the cost as hopefully they have provided the relevant certs etc.
now that his wife has seen where it is she wants it moved to the other side of the garage, again simple high level surface run and out through the garage wall to the new position. approx 3 metres away The company want ÂŁ350 to do this.....
My question is do we get them back or can I move it for him ?
former electrician,retired public sector,as an electrician I worked in industrial,domestic installations and maintenance
any thoughts,
How will this impact warranty?
The supply cable does not come with the EVSE, and instead provided by installer....
Just extend the cable and use suitable glanded junction boxes....
Certificate no longer valid, installers warranty gone as it has been altered instead their last visit. Will need re-tested and certified at new location. Manufacturers warranty won't be void if installed correctly again, but installer will be under no obligation to honour any sort of warranty.
You are over thinking this. It's no different to extending power cord on an extension lead.....
any thoughts,
WHAT EV Charger? That "Armoured cable" most likely includes a CAT 5 or control pair of signal wires as well as mains (depending on the charge point). So beware of that.
Reply to moving an ev charger in the UK Electrical Forum area at ElectriciansForums.net
A day for sure. I recently installed an Anderson with dedicated CU. The run was a fair bit worse as I had to drop a section of ceiling and chop...
Thank you everyone for your comments Celia
