moving consumer unit help | Page 3 | on ElectriciansForums
Discuss moving consumer unit help in the UK Electrical Forum area at ElectriciansForums.net
W
Welshsparky
Been asked to move a consumer unit by a local estate agent as ( believe it or not ) its tucked behind a kitchen unit , only accessible by taking part of the kitchen out! , it's an old rewire able fuse board , if I am to move it, would I be required to change it to an updated rcd protected version? Or if the fuse boards still in good shape could I re-use?
I have recently quoted for a very similar job,cu is in rear of kitchen unit,client would like it in hallway cupboard,not a 5 min job,done a EICR on the place i ended up with a sore neck,bleedin kitchen fitters!
Reply to moving consumer unit help in the UK Electrical Forum area at ElectriciansForums.net
I would hazard a guess your electrician may be able to contact your DNO and have the switch swapped to a MFS very quickly..
