daiplayer
Had a call regarding the movement of a CCU.
The consumer unit is currently located in the kitchen , high level.The main income located in a cupboard about 1m away.PME system , 16mm tails.
It is to be moved. approx 7m away ( under the stairs).
1-)Is there any way the customer can get the main income moved for free since it is found in a special location ?
2-) if not - when moved 7m away , what do i need to do regarding tails/rcd/protection etc.
To my knowledge tails longer than 3m must be RCD proteced. in this case would it be an s type 100m/a in order to meet discrimination between the RCD's on new board ? do the tails have to be enclosed in conduit ? as they will be drilled and run through floor joist ( more than 50mm from surface)
Im asking because the sutomer wants an accurrate 'quote'
Any advice on this would be MARVELOUS
Thanks all
Thanks all
