Moving to a house 3 meters from a 11kv sub station | Page 4 | on ElectriciansForums
Guest viewing is limited
Discuss Moving to a house 3 meters from a 11kv sub station in the UK Electrical Forum area at ElectriciansForums.net
aylesbury
hi
we are looking at a buying a house that has a small 11kv substation within 3m from the edge of the house, it is walled off and gated.
my main concern is emf s given off in and around the house and garden, distribution cables running under the house.
has anyone any knowledge of measuring emf s in domestic houses near substations and if it has health risks associated .
also I guess the voltage will be a lot higher in the house , so am thinking about a step down voltage transformer within house.
thanks dave
The only time EMF really comes in to play is with O/H lines and then only at higher voltages. Look on Google, there’s plenty to read, most of it unfounded.
As for the transformer, I should be dead by now. My workshop of 20+ years backed on to three 11/.433KV 1000KVA transformers.
Maybe this is whats given you crankyitiss
I was cranky before that.
I was quite proud of those transformers. The installation of numbers one and two was the first big job I was involved in as an apprentice. I put number three in after I came out of my time, I did have a bit of help.
It depends on how old the sub is as to the type of cable used. SWA hasn’t been used for quite a while.
I don't know about the UK, but we haven't used anything but 15KV and 38KV (11KV/33KV systems) rated SWA cables for all our MV installations over the years. I remember once using AWA single core cable on a project many years ago, but that was mainly to harmonise with the existing system...
Reply to Moving to a house 3 meters from a 11kv sub station in the UK Electrical Forum area at ElectriciansForums.net
Recommended Sponsor News
Hi everyone,
