multi strand 2.5mm T&E - is it OK to use? | Page 3 | on ElectriciansForums
Discuss multi strand 2.5mm T&E - is it OK to use? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
It would be an extremely good move to have the 1mm / 1.5mm / 2.5mm stranded. The present solid core sizes was one of the worst moves made during the metrification of UK cables!! I'm sure every single electrician here, that has worked with the older stranded imperial cables, would wholeheartedly agree!! lol!!
never seen 2.5 multi stranded twe in harmonised colours only in OLD cables
About time the UK caught up. Been using stranded power cables in Australia for years. As for cost?? It was actually cheaper there to buy stranded than solid, as no-one used solid, preferring the cable that is far far easier to work with and terminate.
Alas, I rarely do electrical work here in the Uk. Guess I have been spoiled, hey?? :)
I don't know why the UK doesn't make more use of stranded cables, they are far superior than that of the solid core cables
Think i've already mentioned on a previous thread that we only use stranded metric cables on our project, we just don't use solid core cables. Come to that, you won't see any T&E cable on this project either!! lol!!
About time the Australian internet caught up with the UK, this thread had been dormant for over a year.
Easier to install, not so sure about being easier to connect, I prefer it but that's my choice
Reply to multi strand 2.5mm T&E - is it OK to use? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
In the 80's I was taught that with PME earthing arrangements we used 16mm for the main earthing conductor, some went a bit crazy and were bonding...
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
