multi strand 2.5mm T&E - is it OK to use? | Page 5 | on ElectriciansForums
Discuss multi strand 2.5mm T&E - is it OK to use? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Our LG fabricated Schneider 3.8KA MV Switchboards have insulated tubular bus bars...
It was Laurence Scott Centaur gear I first came across tubular bars as an apprentice. Later English Electric CFS.
The weird ones were Eutrotherm panels, water pumped through to cool the busbars. Water and electrics together sounds dodgy but it worked fine so long as only de-ionised water was used. Depending on the loading the voltage varied between 300 and 1250V, the earth fault trip was set to 40mA.
Reply to multi strand 2.5mm T&E - is it OK to use? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
In the 80's I was taught that with PME earthing arrangements we used 16mm for the main earthing conductor, some went a bit crazy and were bonding...
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
