Multiple Virgin telephone points | Page 2 | on ElectriciansForums
Discuss Multiple Virgin telephone points in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
depends if the hub has a ring cap in, the master socket the OP has will also generate a ring signal. A lot of phones have the ring cap inside them.
The ring signal is generated inside the modem, so a master socket isn't required. I haven't tried it, but I doubt if there's a ring signal on 2 and 5 out of the modem.
If I'm wrong, and there still is a AC ring signal superimposed on 2 and 5, then the cap. in the master would still couple it to 3.
Yes they wont connect to the ones i wired. Is that just a lead from the hub into the first telephone point?
B.T wouldn't have connected the house extension sockets unless they were previously fitted by B.T.
Yes, I fitted a socket next to where the hub is and I made up a short double ended B.T plug to B.T plug lead. (431a to 431a)
You can buy them, search BT male to BT male.
They used to fit NTE5 same as BT, they usually where fitted side by side. I just wired a link across both front plates, to divert the extension wiring between the two.
Reply to Multiple Virgin telephone points in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hello What was the conclusion of your problem?
I'm assuming there was an original quotation and contract. For a project that size there jolly well should have been? In all my contracts...
