Must bond, must bond, must bond. Pointless bonding pictures. | Page 2 | on ElectriciansForums
Discuss Must bond, must bond, must bond. Pointless bonding pictures. in the UK Electrical Forum area at ElectriciansForums.net
G
GBDamo
Must install a 4" piece of copper as any fool knows it's pointless bonding the plastic.
Anyone beat this for a pointless bonding picture.
[ElectriciansForums.net] Must bond, must bond, must bond. Pointless bonding pictures.
Just to clarify, this isn't a new build, it's about 10-15 old.
It's one of those odd installs where everything is there, in the right place, the right size and spec, good quality components but looks to have been I stalled by a toddler.
Nothing is level, no cables are supported properly, DB- a Hager- correctly populated but no labelling.
Then spend time and effort with pointless bonding.
...Didn't we used to call that "speed-dating"? ;)
Sometimes you do something like that to shut up the health and safety guy with his clipboard and pen demanding all sorts of stuff no sane electrician would do
Most likely demanded by a meter installer that doesn’t have a clue. I once was waiting for a new fuse in a long time empty property & because his volt stick didn’t light up said they would need to dig road up. Until I pointed out the supply branched off & fed next door. Spent the next half hour looking very sheepish while he installed the isolator lol.
Reply to Must bond, must bond, must bond. Pointless bonding pictures. in the UK Electrical Forum area at ElectriciansForums.net
Any metalwork connected to the MET could rise in voltage compared to true earth under an open supply neutral fault (on TN-C-S), and that would...
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
