J
jasonswift
My 90 year old father has just purchased a new oven and hob and employed a local electrician to fit them. I’ve only ever done minor electrical bits myself, wiring the odd socket but just with my very limited knowledge something doesn’t look right about this guys wiring. I’ve asked if he’s qualified as an electrician and he says “don’t need to be, my mates qualified and he’s going to check it when I’ve finished” I’m guessing this isn’t right for a start?
Back to the wiring. There was an existing 30 amp cable which used to power the old cooker, this has now been wired in to a cooker switch, the type with a big red switch and a separate 13 amp socket. The wire then goes inside the kithen units to a junction box. From the junction box there are two cables, one goes to power the hob and the other goes to a new single 13amp socket to power the new oven.
The oven is rated at 2.35kw the hob is 6kw and Dad has a 2.2kw kettle plugged into the cooker isolator socket, total 10.55kw. This seems to be an awful lot connected to one 30 amp cable.
Besides the cable rating there are a couple of other bits that don’t seem right. The cable from the old cooker wiring to the new cooker isolator isn’t buried in the wall, it’s just clipped to the plaster, it’s exposed above the kitchen units, no covering at all.
The new wiring inside the kitchen unit has also been left exposed and just before it enters the junction box there is a 3 inch length of bare copper earth wire. On top of all this he’s told Dad that the fuse box needs replacing, because it’s “illegal” and that’s going to be £250 just for the parts. The house is only 8 years old and has a very new looking fuse box with circuit breaker type switches, none of those old re-wireable type fuses.
Before I confront this guy I need to know if this wiring is OK and what qualifications are needed to do this sort of work.
Any help would be appreciated.
