My economy7 storage heater and water heater are not working. The Triton shower is not working. | Page 2 | on ElectriciansForums
Discuss My economy7 storage heater and water heater are not working. The Triton shower is not working. in the The Welcome Forum area at ElectriciansForums.net
a possible reason for the shower MCB being off is that the shower isolator ( pull cord if in bathroom, or could be a wall switch outside bathroom ) may have a dodgy connection. check to see if it gets hot or smells. best option would be to get a local electrician in to check your installation, as pete 999 said earlier.
That CU was replaced in 2016 yet they didn't see fit to upgrade the shower circuit to RCD protected - unless the small shower board is fed from an RCD protected 'way' in the new board ?
Don't worry Jennifer, it might be worth just getting a decent Electrician in to check over your electrics. There may be a circuit breaker within the newer board labelled shower which supplies the small board above ?
Reply to My economy7 storage heater and water heater are not working. The Triton shower is not working. in the The Welcome Forum area at ElectriciansForums.net
RCD it up for the effort it would take I would suggest. Look at the EV fiasco starting to take shape where no RCDs have been fitted and now...
I am a landlord/owner of a flat. I am just about to spur off nearby sockets to provide the additional 24hr supply to new Dimplex Quantum storage...
