davesparks
I don't know for certain, but I have made the assumption that this did work correctly originally and this has developed as a fault.
Seems to me that it is not wired correctly, would help if we could see the wiring in the back of the switches, but on the assumption that all the cables that are needed are present i would just say it is not wired correctly and the permanent live is probably in the common instead of the L1 or the strappers are mixed up. like i say would need to see the wiring.
As far as I can see the first four operations prove that the switches and the lights and the wiring are all correct.
OK so I have missed something, apologies.I wouldn't be so sure about that,
OK so I have missed something, apologies.![]()
Did you make any typos in your OP then dave?
