Guest viewing is limited
"Hello All",
I have had Freeview on all of the TV`s in My Home since Freeview became available - all with a Great Picture.
I live in London as We have just had the `Switchover` on 4th and 18th April - Since then the TV Pictures have been NOT Great and have been adversely affected by the recent `Bad Weather` / Rain etc.
I am sure that I read often in the run up to the Switchover that the Signals would be `Better` and that Bad Weather would NOT affect the Signals ?
I have never seen the Weather affect the Picture / Signals before the Switchover.
I am near the Transmitter Tower for My Area and have had Great Pictures / Signals for over 25 Years - UNTIL NOW !
I cannot imagine that this means I would need to change My Aerials - Why would I have been receiving Great Pictures in the YEARS preceding the `Switchover` BUT Worse Pictures / Signals since then - when it had been stated that the Switchover would Improve the Signals ?
I have tried having the Aerial positions adjusted slightly - but they needed to be returned to the original positions to receive the now Inferior Signals / Pictures.
I cannot Try / use Signal Boosters as I have Sky wired to and connected to the Aerial Sockets of 2 of the TV`s - a Signal Booster interferes with the Signal from the 2nd Output from the Sky Digibox - I think via the small voltage supply to the Magic Eye for the Remote Controls [?] - causing NO Sky Signal - Remove Signal Booster = Sky Signal Works again.
I am hoping for comments from Members regarding the points about My Freeview Signals being Worse since the Switchover AND the Signals / Pictures being BADLY Affected by Bad Weather / Heavy Rain - as most Areas have had the Switchover quite a long time ago do any Members remember these Problems in their Area ?
Regards,
Chris
Hello,Looking through this long thread, Have had similar problems with retuning Freeview,just a few pointers if you dont already know, Have you tried a New seperate freeview box connected to your scart input on your tv.this would isolate the problem from the tv,
If your TV is a crt type or a flat panel with built in Freeview or seperate box , some older tvs and freeview boxes when retuned have problems with channel dropout on certain channels on digital namley channel 28 , see coverage for programs on crystal palace transmitter info on internet.
Aerials Group A (red) for the London area will cover channels 21-37.A wide band aerial (black) will cover channels 21-68 with loss of gain due to the larger bandwidth.
If you have more than 1 tv connected to your aerial system there must be an amplifier in circuit .try your attenuators in the aerial input to your amplifier for overall signal reduction.Vince.
"Hello Vince",
Thanks for your reply - I have these [previously described] problems on 4 TV`s - 3 of these have Freeview Boxes and 1 has Freeview Built-into the TV - these are connected to 3 Aerials which are located on different parts of the Roof of My Home.
There are NO Amplifiers at all on these TV` Aerials / Aerial Cables and for YEARS before the Digital Switchover I had Excellent Reception on All of those TV`s - I was `Fully Set Up` Years in advance of the Digital Switchover.
The Problems that I have described here started EXACTLY on the SECOND Switchover Day of the Digital Switchover - there was Heavy Rainfall on the afternoon of that day and during periods of the next few Days and the Reception Problems that I have described were displaying throughout those periods of Heavy Rainfall.
As You know there was some very Heavy Rainfall during April and the beginning of May - the same Reception Problems were evident at each period of Heavy Rainfall.
I do have a Spare / New Freeview Box which I did try on each TV at the time of the Switchover / Problems - this did NOT make any difference - the Freeview Reception on some Channels - mainly the ITV Channels - Channels 4 & 5 was still Unwatchable.
I have purchased a Variable Attenuator from Maplin - Unfortunately [For this purpose] there has NOT been ANY Heavy Rainfall since I bought it - I have tried the Attenuator to see if the Signal Strength seemed to Alter from the Highest Setting to the Lowest - there did NOT seem to be ANY noticeable difference.
I am still hoping that I MAY be able to change the Signal Strength during a period of Heavy Rainfall / Signal Quality Disruption to alter the Signal Quality to an acceptable level [?] - I will try this the next time that I am at Home during Heavy Rainfall.
I have been told by a couple of Friends that they had similar problems [although not as bad] at the time of the Digital Switchover - they said that after having problems for DAYS [still during the period of Heavy Rainfall] the Freeview Reception went back to Excellent - Perhaps what I experienced for a few Weeks was a problem with the Broadcasted Signals for the Channels that were affected ? - I hope that this will be the case.
I will Post the Results of My `tests` wuth the Attenuator on here - But who knows when I will get the opportunity to check with the Attenuator during prolonged Heavy Rainfall ?
Thanks again Vince for your interest and reply to Me.
Regards,
Chris
Hello Chris ,
As all your Aerials are affected and are outside and only when it rains, Could be trees in line of sight with the aerials, coming into summer, leaves on the trees, wet leaves, reflecting signal,signals lower when rains .
Are your aerials on poles away from the roof,as roofs when wet, also reflect signals especialy when mounted in loft.
Perhaps this may throw some light on the subject.
Best Regards Vince
Hello Chris ,
Best Regards Vince
"Hello again Vince",
Thanks for your suggestions - the thing is that all of My TV`s / Freeview Reception was excellent for Years - Until the Second Day of the Digital Switchover - I had wanted to have Freeview set up on all of My TV`s well before the Digital Switchover and I had achieved that Years before.
The Aerials are on `Masts` fixed really well to Brickwork they were aligned using an Aerial Signal Meter - they were Checked again recently when the problems started using a different Aerial Signal Meter - all were found to be receiving the `Best` / Strongest Signal.
The Trees around My Home are not particularly close to the Aerials / Roofs and have never caused any concern.
The main `indicator` here is that these Signal / Reception problems started on the Second Day of the Digital Switchover - I was at Home on that Day and I actually saw that from the time of Re-Tuning the Freeview Boxes / Freeview Built in TV that the Reception was immediately disrupted / unwatchable - Mainly on the ITV Channels plus Channels 4 & 5.
I had done Re-Tunes as prompted by the Freeview Boxes - Immediately upon turning them On on that Day and when I had the Reception problems I then carried out a Reset / `Tune from New` Re-Tune - which should have `Cleared` the previous Channels from the Freeview Boxes and then Tuned to the `New` Digital / Freeview Settings.
With the TV which has Freeview built in I carried out a Re-Tune and then also returned to Tune from `New Set Up` [Words to that effect] to have Cleared the previous Channel Set Up and Tuned from a New Installation Set Up.
None of this worked and as You know from April and early May - there was a LOT of Rainy Days & Nights for the Reception Problems to exhibit on My TV`s.
Thanks again for trying to help - your suggestions will probably help other People who have problems that are caused by one of the things that You described.
Regards,
Chris
"Hello Tuttle",
Thanks for your reply and the Link to the webpage about the Crystal Palace Transmitter which is the Transmitter for My area of London - I found the Information interesting although I don`t think that it shows any reason for My Problems - unless the Signal Strength Increase could cause them.
The Information about the `Vast` Increase in Signal Strength [10 Times] seems to show that this would actually `Help` the Reception for areas Close to the Transmitter [?].
Regarding Me contacting Local Aerial Companies to ask about My TV Reception Problems since the Digital Switchover - I am NOT being cynical here But:
They would definitely say that they had to send an `Engineer` to check My Aerials - this would obviously be Chargeable and would almost certainly lead to Me being told that I needed ALL the Aerials to be `Upgraded` to the [Non Existent] `Digital Aerials`.
I am aware of `High Gain` Aerials which are [in My opinion] incorrectly referred to as `Digital Aerials` and what I have fitted are versions of these `High Gain` Aerials.
EDIT - HAVING FOUND THE RECEIPT FOR THE AERIALS THAT I FITTED THEY ARE NOT `HIGH GAIN` AERIALS - JUST GOOD QUALITY `GROUP A` MAST AERIALS.
I have this opinion because when Freeview was first available I wanted to get ready to receive it for the TV`s that I had which were not connected to Sky Digiboxes [at that time] and I did contact some Aerial Installation Companies as I THOUGHT that I would need My Aerials Upgraded to `Digital Aerials` - I was NOT aware at that point that there is NO Such Aerial.
These Companies ALL stated that I would need them Upgraded to New `Digital Aerials` and the Quotes for 2 Aerials were Absolutely Ridiculous ! - Hundreds of Pounds !
I declined and started to research about Upgrading Aerials for Freeview / Digital Reception - I then found out that there is NO such thing as a `Digital Aerial`.
About 2 Years before that I had a New Roof put onto My Home and while the Scaffolding was up I Installed 3 new Aerials - Two to the Main Roof / Chimney`s and One to the Extension Roof Gable End - with help and an Aerial Signal `Finder` I positioned these Aerials to obtain `Great Pictures` on the TV`s.
I also had a Sky Installer check the Sky Dishes for the Cable Connections being Waterproof and that there was no degrading of the Satellite Cables at Roof Level and all the way to the entry points into the Building.
I mention this only to explain that My Aerials were already `New` when I was asking about the `Digital Aerial` Upgrade - I had told all of the Aerial Companies that I contacted what I wrote above - They ALL still told Me that there WAS such a thing as a `Digital Aerial` and quoted Hundreds of Pounds to Install 2 !
When the Freeview Channels became available We instantly had Great Pictures on the Freeview Channels using Set Top Boxes - So I assumed that the Aerials were correctly positioned for Freeview - Luckily.
When I purchased a couple of new TV`s they were obviously had built in Freeview - again I received Great Pictures with the existing Aerial positions.
When I had the Freeview Problems after the Switchover recently I had help from some Friends to check the positioning of the Aerials again - having moved the Aerials around we had to return them to the original positions to get the Best Reception for the TV Channels - although the problems still existed on the Freeview Channels which were problematic.
Since then We have noticed - mainly in Bad Weather / Heavy Rain which We have had plenty of recently - that the problems seem to be mainly on the ITV Channels - ITV1 - ITV2 - ITV3 - ITV4 and sometimes Channels 4 and 5 - there does not seem to be as many problems with the other Freeview Channels and seemingly NONE with the BBC Channels.
I cannot be exact about this because We have not spent Hours and Hours watching ALL of the Freeview Channels at times of these Signal Problems.
Thanks again Tuttle for your reply - I appreciate you trying to help Me.
Regards,
Chris
Isn't it a bit like over gassing ???? :)
"Hello Geordie Spark",
I like the analogy - although I understand what another Member stated about the Signal Strength being too strong and perhaps affecting the QUALITY of the Signal - this would ONLY occur during periods of Heavy Rain - I wonder how likely this is ?
When I tried a Variable Attenuator - [2 Of - from Maplin] during just Light Rainfall there did not seem to be ANY Difference to the Signal / Reception at either the Lowest or Highest Signal Strength - Although there was NO Signal Disruption at that time so I cannot be Certain that I can`t alter the Signal Strength to improve the Signal Quality.
I will have to try again when We get some Heavy Rainfall - probably fairly soon as Wimbledon Tennis Weeks will soon be on !
Regards,
Chris
Regards,
Chris
Aye .... Wimbledon and the annual Geordie Town Moor Hoppings ............. Guaranteed to make it pish doon !!!!
Something else worth considering ... someone was telling me recently that freeview boxes can sometimes tune themselves into weak signals from other transmitters, which can cause reception problems, and I guess could explain your problem with heavy rain.
I think that I have had this problem with one of my boxes. When the regional BBC news came on one box showed news from the south but my other two boxes showed news from London. Searching though the channels I found that BBC London was actually on channel 325 on that box instead of channel 1.
Maybe try clearing all channels and retuning next time you see the poor reception, e.g. in heavy rain when the signal from other transmitters should be weaker. I've also heard that you can enter your postcode into some boxes, or there may be other ways of controlling which transmitter they tune into.
I seem to remember that with analogue TV you would often find snowy channels while tuning, especially on old TV's with manual tuning, but you would just carry on going until you found a strong signal. I guess that the box could auto tune into one of those weak signals and being digital show a perfect picture most of the time.
"Hello Tuttle",
Thanks for your message / suggestions.
I think that the TV Signal that I receive from the Crystal Palace Transmitter is the ONLY Signal that the Freeview Boxes / TV`s can receive where I live.
I believe that it is so `Strong` that it would not allow any other Signal / Transmission to be received where I live in South London - and I have never experienced any other Area`s TV Signal / Channels being received here.
Regarding Retuning the Freeview Boxes / TV`s when there is Heavy Rainfall - I was doing that regularly during the period from the Second Day of the Digital Switchover onwards [during Heavy Rain] for 2 or 3 Weeks.
The start point of these problems was definitely the Second Day of the Digital Switchover - Whatever Upgrades / Processes occurred on that Day [?] - I had Excellent Freeview TV Reception for YEARS before that Day / Date.
Thanks again for your interest and suggestions - I really appreciate your involvement and Help with this.
Regards,
Chris
Not sure what value your attenuator goes up to, but it may not be enough!
To see if it's doing anything look at the signal strength bargraph on the receiver - if it doesn't drop below maximum with the attenuator on max attenuation then either the attenuator isn't working, or it's not large enough (plug two in line one after the other and try again.
Oh, and gthe other thing that can cause problems in high signal areas is poor quality cable, either the aerial downlead/house wiring cable that isn't foil shielded (cheap stuff usually from electrical wholesalers), or the fly lead from the wall socket to the receiver. If it's one of those thin white ones then try changing it for a good quality foil screened one.
Either of these cable routes can pick up signals directly, that then interfere with the 'original' signal from the aerial.
(in all of this I assume the problem you are referring to is 'blocking'/'pixelating' of the picture on screen, rather than some other form of interference?)
"Hello Ian B",
Thanks for your messages.
Yesterday I had the perfect opportunity to try the Variable Attenuator again on the Aerial Cables to My TV`s - Because of the VERY Heavy Rainfall last night which is what causes the Unwatchable Signal / Reception from My Freeview Boxes / Built In Freeview on TV`s.
I also purchased a New Freeview Box to try and see if this was also affected by the Signal / Reception Problem - It Was.
I believe that the Variable Attenuator adjusts from 0 to 20 in the Signal Range [?] I was hoping that IF the problem was that the `New` Digital Signal was too Strong and was affecting the Signal Quality that I could turn down the Strength to achieve a better Quality Signal.
Whatever the Adjustment using the Attenuator - Nothing changed on the TV Reception / Picture Quality - I could not get a decent Picture at all - it is Pixelated / Blocking / Sound badly distorted - Totally Unwatchable.
Because I have previously looked at the Display of the Signal Strength & Signal Quality on the On Screen Display from the Freeview Boxes I did look to see if the adjustment with the Attenuator was altering those values - As far as I could see it was NOT - even when adjusted to the Lowest Signal Strength.
When the Signal Displays are showing during periods of No Reception Problems the Signal Strength is at Maximum but the Signal Quality is only just about 60% - when there is a Reception Problem during Heavy Rainfall the Signal Strength is still at Maximum and the Signal Quality falls to approximately 35 to 40% - this seems to cause the Signal to become absolutely Unwatchable.
This Reception problem seems to apply to just the ITV Channels - Channel 4 and Channel 5.
I will now purchase another Variable Attenuator and try what You suggested about connecting the Two Attenuators together - to see IF that will Lower the Signal Strength and hopefully then Improve the Signal Quality [?] - "Thanks" for suggesting this.
Regarding My Aerial Cables - these were installed by Me when I also Installed New Aerials and the Cable was `The BEST that is available` - I was told this at the Time by an Electrician Friend who advised Me what to purchase - The Cable was definitely `Double Screened` / Copper Screening of the Highest Specification generally available - I was very surprised at the Cost - especially as I need to get enough for 4 Aerials - from the Roof down to various TV positions.
I don`t have Aerial Socket Outlets installed but I do have some Fly Leads made up from the same Cable as I used from the Aerials [Double Screened] - If I ever needed to move the TV`s for any reason - the Aerial / Co-Axial Plugs are also Good Quality as I would never buy or use Cheap fittings on any Electrical / TV / Satellite Equipment [Or anything else in My Home].
What I am VERY aggravated about Ian is that this all Started at the time of the Digital Switchover - I had almost perfect Reception on Freeview to ALL of the TV`s in My Home for YEARS prior to Day TWO of the Digital Switchover [18 April ?]
Nothing changed about My TV Aerials or in My Home on that Day except for the Second Stage of the Digital Switchover !
Something that I find strange is that My Neighbours do NOT have these problems to anything like the extent that I am experiencing on My TV`s / Freeview Boxes - They do have some Pixelating of the Screen for a few seconds at a time and obviously also the Sound is affected - But seemingly not to the extent where it becomes Unwatchable.
My Neighbours have only `Standard` / Inexpensive Freeview Boxes and their Aerials and Aerial Cables are NOT of the `Best Quality` !
Perhaps now that the Digital Switchover has happened My Aerials and Aerial Cables are TOO GOOD !
When I purchase the additional Variable Attenuator I am going to get an Indoor Aerial - not an `Electrical` / Attenuated Aerial - just a Basic Indoor Aerial and Check out the Freeview Reception using that - Perhaps that will `Attenuate` the Freeview Signal enough to make the Signal Quality better - ?
Thanks again for your suggestions.
Regards,
Chris
"Hello",
Tonight during fairly Heavy Rainfall I connected TWO Variable Attenuators together [Ian B`s suggestion] and tried adjusting the Signal Strength from the various Aerials to My TV`s to TRY to get better Signal QUALITY / Reception for the Digital / Freeview Channels that are BADLY Affected during Heavy Rainfall.
I was able to actually See the Signal Strength being lowered on the Signal Indicators from the Freeview Box Displays but the Signal Quality was never increased nor was the Reception / TV Picture any better during these adjustments.
as I have often mentioned in My Posts about this Problem - These Signal / Reception Problems only started on Day Two of the Digital Switchover in My Area / London - for YEARS before this I had already sorted out My Freeview Reception and it was Excellent on ALL of My TV`s.
NOW I still have Unwatchable TV Channels on ALL TV`s except for My 2 `Main` TV`s where Sky is the `Supplier` of the Channels that We watch - these Channels are mainly ALL of the ITV Channels - Plus Channels 4 & 5 - I am still irritated about this as the TV`s in 2 Bedrooms and the Kitchen TV have Channels that cannot be watched during periods of Heavy Rain.
I cannot be `Unique` in having these problems - although as I mentioned My Neighbours do NOT have the Signal / Reception disruption to the extent that I have - If there were `London Wide` Signal Problems I would have expected to have at least Read about / heard about this.
I was not able to purchase an `Ordinary` Indoor Aerial on Sunday when I bought the Second Variable Attenuator as there was not one in stock - But although I probably will get one - JUST to `Rule Out` that option - I cannot imagine that it would produce a `Better` Signal QUALITY than My Top Quality Roof Aerials and Top Quality / Double Screened [Copper] Aerial Cables & Fittings.
Thanks to All Members who have tried to Help Me with this - I really appreciate all of your Time and Suggestions / Information.
Regards,
Chris
Hi Chris.
It's difficult to diagnose much more without a site visit, and my only remaining thought is that your aerial is picking up a reflection or multi-path signal from the same or another transmitter from a wet roof (as it's evident in heavy rain), but this is fairly unlikely. The test with an indoor aerial might eliminate that.
I can only suggest you either get a professional aerial installer to come out and check the system, or contact Digitsal Uk Digital UK - Help although I suspect they will say the same.
Go for a CAI member company and try to choose an experienced one that is familiar with your particular area. Directory Search Page
Let us know how you get on though :icon14:
Hi Chris.
I can only suggest you either get a professional aerial installer to come out and check the system, or contact Digital Uk Digital UK - Help although I suspect they will say the same.
"Hello Ian",
Thanks very much for trying to help Me with this - I really appreciate your Time and your suggestions.
What REALLY irritates Me is that I made a point of getting ready and Fully Set Up for Freeview / Digital TV Switchover YEARS before it occurred - I had almost perfect Reception on ALL of the TV`s for YEARS prior to April this Year.
I wonder what could cause My Excellent TV Reception - on Freeview / Digital to have these problems on Day 2 of the Digital Switchover ?
It would be good to get a Professional Aerial Installers `Technical Investigation`/ Opinion about this - The problem is that even SOME Companies / Individuals who are Registered with the Industry`s Voluntary `Governing Body` are NOT Trustworthy regarding reasonable Charges.
There has been quite a lot of Talk in areas of South London where I know People about a LOT of People being Ripped Off with Charges in the run up to the Digital Switchover for the Installation of Roof Aerials - some by So Called Professional Aerial Installers.
I don`t really want someone coming to MY Home and possibly NOT being able to `Diagnose` the Problem - which could ONLY be checked during Heavy Rainfall as it ONLY exists then - But then wanting to Charge Me an exorbitant `Fee` / Call Out Charge Plus........
I know that this seems as if I am `Putting Down` Professional Aerial Installers - I am NOT - From what I have Read in Newspapers and what I have seen on TV and heard from Friends there are obviously MANY Cowboy Installers who are `Registered Installers` - these People then give the Entire `Industry` and everyone working in it a Bad Name.
I remember the Watchdog / Rogue Traders program that `Exposed` some Registered Installers - they were simply taking the P... out of their Customers with their Work and Prices.
I will check around for recommendations for an Aerial Installer who has done work for someone that I know - and who perhaps is also `Registered Aerial Installer`.
Although I have mentioned often in My Posts how `Irritated` I am about this - that is because I tried to ENSURE that I was Set Up for Digital TV YEARS in advance of the Switchover.
The Unwatchable Channels problem does NOT affect My Everyday TV Viewing - in fact it does not affect ME at all - the Signal / Reception Problems are `On` Bedrooms TV`s and the Kitchen TV - ONLY during Heavy Rainfall.
That is why I would rather NOT have to get an Aerial Installer involved - unless I could obtain Technical Advice and was then able to Eliminate the problems at a `Reasonable Cost`.
To Pay an Expensive Invoice for an Intermittent [Heavy Rain Only] Problems to SOME Channels only on Bedroom 2 and Bedroom 3 TV`s and the Kitchen TV would in My opinion be Foolish.
Thanks again for your help Ian - IF I ever get this sorted out [?] I will Post the Result Here.
Regards,
Chris
Chris,
I understand your frustration, and of course there are good and bad guys/firms in any industry.
You should be aware there is a difference between "Registered Digital Installers" (some, but by no means all, of whom were set up just to do DSO work), and CAI members.
Some firms are 'members' of both, and I'm not saying all of either group are good or bad, but the CAI offers a 'warranty' service to consumers who use one of it's members, so if there is a case of poor workmanship or inappropriate charges, then they can step in and assist the customer. The CAI Promise
I doubt anyone will give you a fixed price to resolve the problem without a site visit first, however, once they've been and identified the problem then they should be able to provide a price to fix it, assuming they don't do so on the first visit.
As a general rule, the guys that do 'systems' work (MATV, SMATV, IRS, etc) will have all the test gear and be experienced. Again I'm not saying residential installers won't have the same gear, as with all trades there are those who are more 'technical' than others.
Good luck!
Ian
LONDON
MY TV`s FREEVIEW CHANNELS HAVE WORSE PICTURE QUALITY AFTER SWITCHOVER !
FreeSat, Sky, VirginMedia Forum
chris murphy,
chris murphy,
