G
gedberm
Hi all,
Long story shortened:
In a Terrace, next door blew his fuse (big bang and sparks apparently) and it tripped our leccy too. His came back on once he'd changed fuse, ours didn't - RCD wouldn't reset.
Power Co came out and put the earth cable over to the neutral - result? RCD reset but put more than 2 lights and one plug socket on and it'd trip.
Next visit from Power co, went thru board and managed to get every circuit working apart from ring main (they're not sure how, just removed wires and refitted them).
As they now think it's an internal problem (can't see it being anything else really) it's now down to me. They've left it with ring main wiring removed completely from box.
I've removed any spurs that I can get to/identify and all appliances. I've checked the neutral connection to each socket but as soon as the neutral is dabbed on the neutral bar in the box it trips the RCD.
Apologies for the incorrect terminologies etc....would appreciate any suggestions as this is causing major problems!!!
Many thanks, Ged
Many thanks, Ged
