Name of Device being used? | on ElectriciansForums
Discuss Name of Device being used? in the Talk Electrician area at ElectriciansForums.net
tmitchell
California
Anyone know what kind of device this is and brand name used? Its connected to a pressure switch.[ElectriciansForums.net] Name of Device being used?[ElectriciansForums.net] Name of Device being used?
I think we need to know what it’s connected to electrically, and it’s function.
The symbol on it describes what sort of valve it is, but it’s too blurry. Another photo would help.
It won’t matter if it’s pneumatic, hydraulic or a beer line….. it has a function, and with only 3 ports, I’d suggest a changeover valve (like a two way switch)
The tubing is connected to a blower or vacuum unit into the single opening and then run into an air pressure sensing switch with an an adjustable set point. One of the tubes is connected to the the low and the other the high.
Yeah it's a pneumatic valve. Can you post a better photo so we can make out the symbol printed on it.
Thanks for identifying the device. Wish I had a better picture, its from a video with low res. Here is another image of the device from a different side, thing that might help is there is a red dot on the side of the device.
  • [ElectriciansForums.net] Name of Device being used?
It's a changeover valve. You can just make out the arrow symbols,in the first picture,which show direction/port connection,in it's actuated and at rest position.
Match it correctly,as some have exhaust facility,some not.
Looks like a pneumatic solenoid valve. It is used to direct or stop the flow of compressed air in a pneumatic system. Sometimes called a directional control valve, they are used in automation and control applications to actuate tools
Reply to Name of Device being used? in the Talk Electrician area at ElectriciansForums.net
Gents has anyone done an application using the UKPN smart connect portal for a split phase supply and addition of multiple single phase battery...
pretty sure from memory they are indeed designed to work on both frequency's, Best check with Schneider but I think they will work on 60 HZ
