I think we need to know what it’s connected to electrically, and it’s function.
The symbol on it describes what sort of valve it is, but it’s too blurry. Another photo would help.
It won’t matter if it’s pneumatic, hydraulic or a beer line….. it has a function, and with only 3 ports, I’d suggest a changeover valve (like a two way switch)
The tubing is connected to a blower or vacuum unit into the single opening and then run into an air pressure sensing switch with an an adjustable set point. One of the tubes is connected to the the low and the other the high.
Yeah it's a pneumatic valve. Can you post a better photo so we can make out the symbol printed on it.
Thanks for identifying the device. Wish I had a better picture, its from a video with low res. Here is another image of the device from a different side, thing that might help is there is a red dot on the side of the device.
It's a changeover valve. You can just make out the arrow symbols,in the first picture,which show direction/port connection,in it's actuated and at rest position.
Match it correctly,as some have exhaust facility,some not.
Looks like a pneumatic solenoid valve. It is used to direct or stop the flow of compressed air in a pneumatic system. Sometimes called a directional control valve, they are used in automation and control applications to actuate tools
California
United States of America
Name of Device being used?
Talk Electrician Forum
Thread Tags
tmitchell,
timbobelfast,
