NAPIT Assessment Equipment | on ElectriciansForums
NAPIT Certification Scheme NAPIT Assessment Equipment
Discuss NAPIT Assessment Equipment in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
S
Spazz
I have my NAPIT Assessment coming up in the next week and want to make sure I have the right equipment.
If someone can post a list of minimum required equipment that would be great, as most people I don't want to go and buy something else especially if the equipment I have does the job to the standard required.
All they say is:
Instruments - there must be access to sufficient instruments to carry out tests relevant to the scope of work carried out by the applicant and which could include: voltage, insulation resistance, continuity,
polarity, earth fault loop impedance (circuits and external), operation of RCDs.
The basic equipment yes - just making sure they are not going to be picky.
I am newly qualified and as you can expect with colleges they have all the latest, but does not help the average new Joe who has a budget to keep to.
Is there anything you can recommend I should have as a minimum, of course I have a reasonable multimeter, Socket Tester, etc
The only thing i'm not sure about is the operation of RCDs tester?????? - any recommendations as the college had a nice tool which you plug the RCD into - again useless unless you have a few hundred to spend on a tool with one function.
Your Tester/s should also have current callibration certificate
Are you asking about testing your current rcd test instrument or about not owning rcd tester?
This is also another reason why Im asking to make sure that I am ready.
I think I am but always better to have a 2nd opinion.
Minimum would be a multifunction installation tester. Lots of companies make them, I'd have thought a newly qualified spark would be familiar with a lot as his/her company would have some test gear and as you state the colleges have them. If you look hard enough you can often pick them up for reasonable prices.
What is it that you have?
Does it have a recent calibration certificate? If it doesn't get it done or you will most likely fail
Do you have all the required paperwork in order?
I have all the paperwork in order I think - I have had it checked already by the lecture from college and he was happy, a few pointers but all done now - he was just no help when it came to the equipment as hes used to the college ones and dont know what else is on the market.
Thanks for all your help - It appears that I do have one.
<<<<eh?.....you need to know what test instruments you have and how to use em....in a safe manner and in the way they were designed to be used so as to achieve correct values etc......if you dont know this stuff...how are you going to present a full cert for the work you will/should have carried out as per terms of a part p assessment?...hmm....
so if your lecturer is not conversant with differeht types of test equipment (different manufacturers etc) then whats he doing lecturing?.....for instance a loop tester ..is a loop tester...some use dloc (robin)..others use low current loop..(megger, metrel, fluke) etc....the same for an RCD tester.....or a low resistance ohmmeter.....
I have the SOK 36 Professional Socket/Earth/Loop/Polarity/RCD Tester.
I only had it about a month ago and haven't used it as yet.
I have tried to post a link but it appears not to have come up - something about a Mod confirming it - hence the delay
I have been with another spark for the last 3 months since I passed, he then had some personal problems so the owner of the company (a property management company) has told me to kit myself up and get the NAPIT assessment done and I will take over.
If I have any problems then I can call on the spark, but due t what happened and how soon I dont want to start asking him questions at this delicate time.
Most of the work that I do is changing socket covers, CUs, Switchs, installing showers, etc.
Its only when the tenant says that something is not working I go in and fix it.
Reply to NAPIT Assessment Equipment in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
How many times you visit multiplied by five mins sounds about my level, except I then get more notifications and keep coming back.
What was the assossors name? Was it warren by any chance? Did you get it sorted in the end?
