Discuss Need electricians advice. Moving ceiling light without chasing ? in the Lighting Forum area at ElectriciansForums.net
you are probably right. do you think i should leave it as it is and just put a spot light unit there? or do you think i should used curved trunking? or find some kind of track lighting?You have a long way to move over compared to the one in that link, it would not give the same effect and in my opinion you would quickly regret it.
What you do is get an adapter for the track to put any light you want on to the adapter. i.e. a track light adapter you would be looking for.
Exactly that. You should also make sure you get the terminal end which the wire/supply goes into and attaches to the track. As a slight aside you can get the track to go at 90 degrees as well with a 90 degree connector.thanks so much for your reply
https://www.amazon.co.uk/Flicker-Di...&qid=1557149109&s=lighting&sr=1-2-spons&psc=1you would need 5 x 5watt LED bulbs to match the light output of those halogen ones. not seen G9 > 3watt.
lol thanks, so the length of them doesnt effect the brightness? it would be just as bright as a regular length one?that looks like a solution. they are shorter because the clue is in the description....compact. ( that does mean they fit in a lampholder, not a make-up bag. .)
6000K colour temperature in a living room - yuk!https://www.amazon.co.uk/Flicker-Di...&qid=1557149109&s=lighting&sr=1-2-spons&psc=1
i found these ones but i have no idea why they are not as long as regular g9 bulbs
Reply to Need electricians advice. Moving ceiling light without chasing ? in the Lighting Forum area at ElectriciansForums.net
