Need some advice and to introduce myself | Page 2 | on ElectriciansForums
Discuss Need some advice and to introduce myself in the The Welcome Forum area at ElectriciansForums.net
Yes but they said I can move the unit up meaning I can get a split board anyway so it will fit in if I move the unit... what I want to know is given the choice what would other people use... I've never considered rcbos because last time I looked I was looking at around 100 extra for about 4/5 circuits i think it was which is the only time ive looked because in my eyes it wasn't worth the extra
Bare in mind I have 2 circuits so a split board will have them on separate rcds anyway
Control,Gear 8 way RCBO board c/w main switch and 6 RCBOs is ÂŁ109 inc. VAT. no functional earth leads with this model.a doddle to fit.loads of space above RCBOs.no brainer.
only fault i could see was no round K/Os, you need to drill them if required.
a RCBO is a MCB and RCD combined in 1 MCB sized unit, so no additional RCD is required. the only drawback is that the RCD part is not double pole, so will not isolate a N-E fault.
Reply to Need some advice and to introduce myself in the The Welcome Forum area at ElectriciansForums.net
Thank you 👍🏻
