View the thread, titled "Need Some Advice / Guidance" which is posted in Commercial Electrical Advice on Electricians Forums.
I assume if there's plumbers with Arms access it's because they're registered with an electrical scheme...
more like usual plumbers . get in everywhere they should not, like shoving their nasty pipes in the holes that we've spent all day drilling for cables.
Just to keep you updated
Did a bit of the grunt work myself eg bending and threading conduit :D
Sparks are coming in end of this week or start of next to finish up
It is perfectly acceptable for the armour of a swa cable and metal containment such as steel conduit and trunking to be used as an earth providing its continuity is satisfactory. The swa cable should be fitted with "banjos" though.
Im guessing when they installed the Crabtree board which was probably a replacement for an actual metal DB they somehow neglected to connect the conduits to the MET of the consumer unit
There’s a soloution for that cut them out and put a stop end on just before the joiner boards over whatch their face when they can’t understand how something’s not working :coldsweat::tongueclosed:
Reply to the thread, titled "Need Some Advice / Guidance" which is posted in Commercial Electrical Advice on Electricians Forums.
