Neff hob with a plug - can it be hard wired?
Interesting. Not seen one of those sockets on a job before.
But anyways, of course, the hob will be hardwired into an appropriate connection plate, minimum breaker size 16A.
Those connections are for an oven and microwave combo oven. Not had a close look at the hob yet but it’s a 7.4KW induction hob.
Are the manufacturers always correct?
The heater panels I installed recently were of 2 sizes...by that I mean 350W and 700W respectively.
The 350W ones came with a cable and no plug, the 700W ones had a moulded on plug.
I put plugs on the small ones, with 3A fuses.
The big ones had 13A fuses installed in the plugs. I substituted 5A.
During a telephone call with the suppliers I mentioned this...they said I'd probably just want to hard-wire the whole lot anyway, and wouldn't comment on fuse size.
Anyway, it is clear that they had no issue with removing factory-fitted plugs.
