Neon screwdrivers help!!!! | Page 2 | on ElectriciansForums
Discuss Neon screwdrivers help!!!! in the Australia area at ElectriciansForums.net
S
Sparky12021986
ok 2 part thread first is a question that i need to ask....
With regard to test equipment used by electricians state: Why the use of a screwdriver incorperating the use of a neon indicator, for verifying isolation does not comply with the requirements of GS 38...
THANKS....
and part 2 of this thread is to ask you all what is your views on the neon screwdriver as i have heard that a lot of people do not like them where as some others do like them...
They include a neon because they cant even give them away so they force them on you.
But i was in CEF today and on the counter was a box of testers reduced from ÂŁ1.99 to 99p thinking of getting a job lot and flogging them on here ......................to open air-fix paint pots OBVIOUSLY. ;)
Looking at the recent post re British Gas I hope they don't find out about this just in case they decide to add it to the testing equipment that they issue!!!
THANKS....
these things are deadly ...and should be banned..or summat.....if you need to verefy wether a voltage is present/sitting on something...whatever then an approved voltage indicator to GS38 is the answer.......seen loads of kitchen fitters pull these "neons" out of the toolbox and it makes me cringe.....should all be snapped in half or hammered to bits wherever they turn up......neons that is......
[ElectriciansForums.net] Neon screwdrivers help!!!!
I used to use a neon driver as an apprentice before I (and my boss) discovered volt sticks. If you're well earthed they go really bright and you can actually feel the current going through you. Pointless tool really given the existence of the volt stick.
I was once asked to leave a Focus store after starting an argument with a member of 'staff' over these bloody things.
The manager just wouldn't accept my point of view.....maybe it was the way I was trying to get it across.:83:
Theres a thread on here about it somewhere.
Reply to Neon screwdrivers help!!!! in the Australia area at ElectriciansForums.net
Advice needed regarding sealing? Or Are these tiles faulty? I've recently bought Johnson 'Orkney Stone' ceramic floor tiles from B&Q. Paid to...
drowninginit
Heh I know the brochures for courses with stock images of women using tools in random scenarios but when you're there it never happens, it's all...
