View the thread, titled "Neon screwdrivers help!!!!" which is posted in Australia on Electricians Forums.
Sparky12021986
ok 2 part thread first is a question that i need to ask....
With regard to test equipment used by electricians state: Why the use of a screwdriver incorperating the use of a neon indicator, for verifying isolation does not comply with the requirements of GS 38...
THANKS....
and part 2 of this thread is to ask you all what is your views on the neon screwdriver as i have heard that a lot of people do not like them where as some others do like them...
They used to be standard kit in the 1960s but I wouldn't use anything other than a proper voltage tester and proving unit nowadays.I don't really trust testers with filament lamps either.
They include a neon because they cant even give them away so they force them on you.
But i was in CEF today and on the counter was a box of testers reduced from £1.99 to 99p thinking of getting a job lot and flogging them on here ......................to open air-fix paint pots OBVIOUSLY. ;)
Looking at the recent post re British Gas I hope they don't find out about this just in case they decide to add it to the testing equipment that they issue!!!
THANKS....
these things are deadly ...and should be banned..or summat.....if you need to verefy wether a voltage is present/sitting on something...whatever then an approved voltage indicator to GS38 is the answer.......seen loads of kitchen fitters pull these "neons" out of the toolbox and it makes me cringe.....should all be snapped in half or hammered to bits wherever they turn up......neons that is......
now we all know you meaN KITCHEN FITTERS.
We use junior testoscopes as approved pieces of kit, we can only use them to prove live as there's no proving unit for them
Junior Testoscope
Drummond test lamps are used the most though, we don't touch 'volt sticks' as they're very erroneous!
I used to use a neon driver as an apprentice before I (and my boss) discovered volt sticks. If you're well earthed they go really bright and you can actually feel the current going through you. Pointless tool really given the existence of the volt stick.
  • given the existence of the volt stick.
    another piece of kit that can be trusted as far as a politician​
I was once asked to leave a Focus store after starting an argument with a member of 'staff' over these bloody things.
The manager just wouldn't accept my point of view.....maybe it was the way I was trying to get it across.:83:
Theres a thread on here about it somewhere.
Reply to the thread, titled "Neon screwdrivers help!!!!" which is posted in Australia on Electricians Forums.
