I swapped a db on a job yesterday and there is a fault on the heating circuit and i just cant find it in the most disgusting house you have ever seen what is the deal with putting it on the non rcd side? can i do it
Discuss Neutral earth fault in the UK Electrical Forum area at ElectriciansForums.net
its feeding an old immersion tank and two sockets in the bedroom havent done IR as it would mean rooting about in the bedroom having to unplug everything and i have to make clear how manky this house is but it isnt tripping it straight away some times it will stay on for two min some times a hour so im guessing its only tripping under load
Yeah disconnect the element from the supply and try IR between L-N and N-E if eaither are short theb that's mostly your problem. You'll get dead shhort between L-N but you knew that anyway
Reply to Neutral earth fault in the UK Electrical Forum area at ElectriciansForums.net
