Neutrals! | Page 2 | on ElectriciansForums
Discuss Neutrals! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
another quick way is to check switch in hall or landing should be a 3 core between switches if its 2 core youve got borrowed nuetrals
and that little link from the hall switch to the landing switch is a dead giveaway (or live , if you prefer)
Hi
can someone please advise me as the best and easiest way to see if a house has borrowed neutrals, I have trawled previous posts but can't really find any clear answers.
All help is appreciated.
I have a couple of ideas but just want to see if I am thinking correctly.
My current college tutor says you can't test for a borrowed neutral.
Craig
Coming straight to the point about if you want to see if the neutrals are being shared.
If you use a clamp meter on a neutral and monitor the load going through it. Turn all the circuit.
If there are no shared/borrowed/stolen neutrals the load will go down to zero.
If the neutral is shared/borrowed/stolen you will have a current running through it.
if you repeat this for each circuit.
I did this on a cooker cct that I suspected of being used for the neutral of some under-cupboard lights. With the cooker off, and lights on, the neutral current at the DB was just right for the relevant lights.
A shared or a borrowed neutral has to be seen in the time it was done technically sparks have come a long way since then ie we would not dream of doing this but then it was acceptable plus some sparks I have worked with were not the sharpist knive in the drawer and technically they could not put a nut in a monkeys mouth plus some were just plain lazy or under pressure to get the job done so instead of looping a neutral they borrowed one they were not to realise that 40 years later a thing called an RCD that just will not forgive you if you dont get the wiring right.
So yes it is all very well pointing or wagging a finger but things have come a long way
Reply to Neutrals! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Only the N side of the lamp would be at 0v if you went further along the element the voltage would rise.
Hi all, I've been at this all night for a smart switch I've installed for exterior lighting for the house located in the eve's of the house attic...
