New 5 way Consumer Unit Economy 7 to Change from BS3036 | Page 2 | on ElectriciansForums
Discuss New 5 way Consumer Unit Economy 7 to Change from BS3036 in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
You should call your part P scheme technical helpline and ask their advice. That's part of what you pay them for. As with any work though, if you are not sure of what you are doing, you probably shouldn't be doing the work for a paying customer.
he's already stated he's not a member of a scheme!
Have you looked at the photos - I doubt very much you'll get a dual tariff in that space and comply with the regs!
Could put some battens in & board out past the level of the DNO board, move the MET down or rewire into new cu then mount a dual tariff unit on the board.
If you were approved you cold have given SBS a call he does dual tariff all compact rcbo boards....
Hi Guys!
Need advice for my first Consumer units change. I am qualified to PART P, and Domestic Electrical Qualified not registered on scheme yet hence doing this job for a friend.
I want to get the job right as be reference for Napit when i join.
My issue is Have day rate and night rate cables connected to MEM 5 way box for day rate and cable going to consumer BS3036. Should i just change the BS3036 small consumer to Breaker and on/off switch or mould it to one box with Mem 2000 Day box!
Picture links above. just trying to think of way keeping both rates in one small consumer unit. Any suggestions be great!
Have the main consumer covered using a Wago Din and new consumer RCD protection.
Link https://www.facebook.com/photo.php?...44756456170.1073741832.100005919430163&type=1
Oh no, not another lol
Reply to New 5 way Consumer Unit Economy 7 to Change from BS3036 in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
Interesting what you say, I have allowed with my system for the change to be half hour out, so start charging at 0:30 and stop at 7:30 but night...
