New Build IR Testing RFC, can't find the issue | Page 2 | on ElectriciansForums
Discuss New Build IR Testing RFC, can't find the issue in the UK Electrical Forum area at ElectriciansForums.net
Loindon
I am currently testing a 2 bed flat, all other circuits read clear. Flat Ring not so much.
Using a Megger MFT1721
L - E Reading 300Mohms but slowly
L - N Reading 400 Mohms but slowly
N -E Reading 200Mohms but slowly
Have tried breaking the ring and narrowing down the problem but both sides come up with higher readings.
Have replaced half the ring and still no change.
Each leg reads +999
You pit a couple of sockets together it starts to drop. Tried replacing parts of ring with 2.5 to see if I can clear it but its not working.
Trying replacing a lag at a time tomorrow...
The plot is a new build so I would expect the readings to jump above 300 right away, so slow readings mean I'm having to investigate.
Does anyone here have any idea what could be causing these readings?
Not too sure I'd be happy with that on a rewire or new install, damp from plaster or not.
Surely this comes from the experience of un-doing all the sockets , letting them breath , getting a much better reading .. logic .
( if worried about tracking damage - I can see AFDs turning up sooner)
Is this "Damp from New Build plaster" effect common only in hot weather ?
Reply to New Build IR Testing RFC, can't find the issue in the UK Electrical Forum area at ElectriciansForums.net
It is actually specified in BS7671 that the cpcs must be connected to all other sources of earth.
https://professional-electrician.com/technical/replacing-a-consumer-unit-in-a-dwelling-niceic/ All circuits should be tested
