New build outside light | Page 6 | on ElectriciansForums
Discuss New build outside light in the UK Electrical Forum area at ElectriciansForums.net
Ayr
Hi, is it a requirement to run an earth wire to outside light(although its double insulated) or is it probably just best practice ? I was replacing my son,s existing outside light on a new build house with a pir security light but found there was no earth to his existing light. Thanks
Reply to New build outside light in the UK Electrical Forum area at ElectriciansForums.net
Good luck with your project and I’m starting in 2 weeks to install the same thing as you.
Some pir lights have a switched output so you can link them together, when any pir is activated then all lights will come on. if you don’t connect...
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
I can't help wondering about earthing arrangements and how important aesthetics really are when attempting to make the best of a less than ideal...
nicebutdim
N
