M
mags1972
Hi all,
Not done any New Build work for a while now, am I right in saying the spec should be:
Thanks in advance guys!
- Minimum Socket Outlets as per Table 8B 17th Ed On Site guide
- 33% all light fittings to be low energy pendants or equivalent
- Extractor Fans in all Bathrooms and w/c's, if no opening window then they must incorporate a timed overrun and then a triple pole isolator.
- Seperate Lighting Circuit for each floor
- Seperate Ring Final Circuit for Each Floor and Kitchen
- Smoke Alarms for each floor and Heat Alarm for Kitchen
- Consumer Units to be mounted between 450mm and 1200mm
