new builds and regulations | Page 2 | on ElectriciansForums
Discuss new builds and regulations in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Big house builders do it all the time. Buy land, obtain planning, do some petty work like a bit of grading and sticking a few man holes in, jobs been started so planning can't lapse. If there is a building reg change like u values for the amount of insulation etc it doesn't matter as it was designed when it did comply.
I think that shouldn't be allowed, if the install hasn't been started then when it is it should be installed to the current regs, in my opinion.
Would you want to jump on a plane with an engine part newly fitted 9 months after regulations had deemed it too dangerous. I'd like to see that argued in court?
If it was dangerous it wouldn't be in commission
You don't C2 a plastic consumer unit if it's fit for purpose
On the site, all of the houses finished before 2017 are plastic. All after arent. The test sheet is written out to the 2015 ammendment with no comments or departures. Also I've just noticed it has no signature for a qualified supervisor.
I don't..your a house builder and buy a bit of land at x amount based on the current building regs. Building regs change and now the insulation depth is double that of the previous. Now its double the cost to insulate a house. Say they priced it at 4K material per house and it's now going to cost 8K per house and they have 300 houses. Due to the change they've got to find another 1.2 million. How would that be fare?
Reply to new builds and regulations in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Yeh im unsure without a photo of external box.
Hello all easy cert users, ive been using easy cert since 2001 with no yearly subscription. and also found other people looking for older versions...
