new builds with no rcd protection?!? | on ElectriciansForums
Discuss new builds with no rcd protection?!? in the UK Electrical Forum area at ElectriciansForums.net
michaelw6
swindon
i have recently been into a couple of property's which are apartments with no rcd protection. there are about 40 of these apartments in this block all of which i assume are the same.
i have checked the main incomer which just goes through an isolator and 80a mcb to the apartment with two supplies, these go into a quickline 2 board with two main isolators either side split peak and off peak.
with 17th edition i did not think this would be aloud.
Im requesting they change the mcbs for rcbos what are your views in case ive missed something here!
you say apartments.
Skilled person present?
Janitor/care taker with relevant qualifications?
I agree they should have at least some rcd protection but just trying to think of why they wouldn't.
I guess you could also rule out use of exterior sockets/appliances on anything above ground floor.
Reply to new builds with no rcd protection?!? in the UK Electrical Forum area at ElectriciansForums.net
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
I will go over and get some photos, the CU is well labelled and very long with many breakers. I never seen one that big in a small flat but then I...
