new builds with no rcd protection?!? | Page 2 | on ElectriciansForums
Discuss new builds with no rcd protection?!? in the UK Electrical Forum area at ElectriciansForums.net
michaelw6
swindon
i have recently been into a couple of property's which are apartments with no rcd protection. there are about 40 of these apartments in this block all of which i assume are the same.
i have checked the main incomer which just goes through an isolator and 80a mcb to the apartment with two supplies, these go into a quickline 2 board with two main isolators either side split peak and off peak.
with 17th edition i did not think this would be aloud.
Im requesting they change the mcbs for rcbos what are your views in case ive missed something here!
Yup I agree I've been reading and I cant really see any valid loop holes as to why they wouldn't put them in.
either designed to 16th or not designed to bs7671 (not law don't forget) don't ask me how they got signed off though.
yes 16th edition design i reckon.
but i dont thing there should be no rcd protection at all even 16 required some protection.
although both apartments i checked were not on ground floor...
If it was designed to the 16th edition, you could get away with no rcd protection in flats above ground floor where sockets would not be expected to be used outside and supplementary bonding was across all bathroom circuits.
With one exception - an electricians home.
Seriously.
Think about it.
No, you can't, because you can't control who else comes into the home. No domestic dwelling can be considered to be under the control of anything other than an ordinary person under any circumstances. The guidance will confirm this.
Wiring in steel conduit? Unlikely in this day and age but would make it 17th compliant - RCD needed where no other protection, and all that. An RCD isn't a 17th must-have, it's just the easiest way to meet the requirements.
PJ
They probably got signed off because , as usual, the building inspector doesn't know what he is looking at and just sees a certificate. The blame at the end of the day lies with the person who signs the certificate.
PJ
It is if you want a bathroom in the property that utilizes 230volts circuits and sockets outlets to BS 1363
Reply to new builds with no rcd protection?!? in the UK Electrical Forum area at ElectriciansForums.net
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
I will go over and get some photos, the CU is well labelled and very long with many breakers. I never seen one that big in a small flat but then I...
