new consumer unit certification | Page 4 | on ElectriciansForums
Discuss new consumer unit certification in the UK Electrical Forum area at ElectriciansForums.net
What certification do I need when replacing a consumer unit ?
Here are the details.
I am semi retired (electrician) and work for a company as the maintenance man which rents out flats as serviced accommodation, we are currently in the process of having the flats (25 of them) tested (fixed wiring testing EICR)
We have brought in an outside company to do the testing and one of the flats will require a board change.
The company have quoted for this and various other C1 and C3 fault rectifications and as well as that have said that the smoke detectors require work done to them as well.
I know that the smoke detectors are out with the scope of an EICR and together with some of the other "faults" they have flagged up I think they are trying to generate income.
Can I change the board myself ? if so what certification would I need bearing in mind all the fixed wiring has been tested and the results logged on the EICR.
We are in scotland and I've trawled tinternet for the answers but its very confusing, is it a minor works certificate needed ? building control informed ?EIC ?
Ta
Ta
Do these flats fall under the Scottish PRS? If they do you will need to be NICEIC or SELECT registered, else have a valid SJIB card and jump through those hoops?
As far as I can see the "Scotland warrant" (in part) is the equivalent of the "English Party Wall Award" for which a "Party Wall Surveyor" has to be appointed, I wonder how many of you guys have worked on a party wall without the necessary clearance/award being in place? 😇
Just to be clear the "Party Wall Surveyor" work for the Act not either party on the respective sides of the part wall.
So long as you have a certificate from the installer to show it was done to a professional standard then I don't see any problem at all.
The council are basically washing their hands of the matter!
Reply to new consumer unit certification in the UK Electrical Forum area at ElectriciansForums.net
Also Merry Christmas and Happy New Year from Electricians Forums. :) I think 2025 should see some house building going on which will free up...
I usually put something like this To assess compliance with BS7671 for continued safe operation (5 year periodical inspection)
It won't be notifiable though as its not a new circuit, if you change the the tails from 16mm to 25mm is that notifiable? No, if you add an...
