What certification do I need when replacing a consumer unit ?
Here are the details.
I am semi retired (electrician) and work for a company as the maintenance man which rents out flats as serviced accommodation, we are currently in the process of having the flats (25 of them) tested (fixed wiring testing EICR)
We have brought in an outside company to do the testing and one of the flats will require a board change.
The company have quoted for this and various other C1 and C3 fault rectifications and as well as that have said that the smoke detectors require work done to them as well.
I know that the smoke detectors are out with the scope of an EICR and together with some of the other "faults" they have flagged up I think they are trying to generate income.
Can I change the board myself ? if so what certification would I need bearing in mind all the fixed wiring has been tested and the results logged on the EICR.
We are in scotland and I've trawled tinternet for the answers but its very confusing, is it a minor works certificate needed ? building control informed ?EIC ?
Ta
Ta
