New consumer unit install issue. | Page 2 | on ElectriciansForums
Discuss New consumer unit install issue. in the UK Electrical Forum area at ElectriciansForums.net
Iona222
Trainee
London
I'm working with my friend a sparky. He changed the consumer unit.
Before hand I checked all circuits for continuity and done quick eicr, everything was OK.
Now with the new board on were getting a neutral fault showing on socket ring. Funny thing is the rcd manual test button isn't working. On the rcd coving the said ring. You think it could be something to do with this why showing a fault on ring. Thank you.
I read that you can get a error from neutral to protective earth if the cpc is oversized.
the extended cpc has nothing to do with it. you have a N-E fault on the ring circuit which is inhibiting thr RCD. i don't know the theory behind this but i've had it a couple of times.
OK what do I do then, I had all the sockets off, Its passing I.r. what you suggest?
Its not the "oversized" cpc. You've been told that. Have you measured earth leakage from the circuit whilst energised? Have you done an IR test of the circuit to the MET, have you ensured the neutrals are in the correct bar. Have you split the circuit in half and tried energising 1 leg?
No he's grabbed the money, ----ed off, saying he's busy.
He's been paid for the job despite it not being complete? And left his trainee to fix it? Why did the customer pay him before the job was finished?
Are we getting the full story here?
In your OP, you say there is a neutral fault. Later you say the circuit has passed IR. Please can you explain this, so we are better placed to advise?
Reply to New consumer unit install issue. in the UK Electrical Forum area at ElectriciansForums.net
2 3
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
